Innovative Mercedes-Benz Citaro is "Bus of the Year 2013"
Mesajde zofei.2006 pe 22 Sep 2012, 14:06
• The Mercedes-Benz Citaro Euro VI prevails convincingly in an international comparison
• Economic efficiency as main focus of development
• Numerous safety features set new benchmarks
Stuttgart/Versailles/Hanover – Its technical innovations have helped it to knock the technical trailblazers of a new era out of the running: in this year's rivalry for title of "Bus of the Year 2013" the new Citaro with Euro VI engine won the overwhelming support of the international jury of experts, way ahead of its competitors, almost all of whom were relying on hybrid technology. The new Citaro is already the first standard-production regular-service bus to include Euro VI technology and continues to extend its competitive advantage. In order to conform with Euro VI, the buses feature a complex emission control system that combines the familiar Mercedes-Benz SCR technology comprising AdBlue injection and an oxidation catalytic converter with an exhaust gas recirculation system and a closed-loop particulate filter. A completely new generation of engines in conjunction with this complex emission control system takes emissions to the very margins of detectability, thus representing a further step in the ongoing development of diesel technology.
Jury member Stuart Jones presents the prize for "Bus of the Year 2013" to Hartmut Schick, Head of Daimler Buses, at the IAA 2012 in Hanover. From left to right: Stuart Jones, jury member, Hartmut Schick, Head of Daimler Buses.
"Our prime concern when developing the new Citaro was that we should be able to match economy and efficiency with corresponding gains in performance, safety and comfort", emphasised Hartmut Schick, Head of Daimler Buses. The beating heart of this "economic miracle" from Mercedes-Benz is represented by the newly developed BlueEfficiency Power engine series, consisting of the six-cylinder in-line units OM 936 with a displacement of 7.7 litres and OM 470 with a displacement of 10.7 litres. Both engines meet the Euro VI emission standard as a matter of course and are characterised by their durability together with their low consumption of fuel, oil and AdBlue. Such technical innovations have, however, neither increased the weight of the Citaro nor reduced its spaciousness. Also helping it to make economic savings is an innovative 24 volt recuperation module: energy produced without any expense by the alternator during overrun phases is stored in double-layer capacitors, known as supercaps, which the bus can then use as an additional source of energy during the acceleration phase. The lower boarding height at the rear doors also helps to reduce energy consumption. Overall, the Citaro achieves fuel savings of between three and five percent. Given normal usage, this corresponds to a good 1000 litres of diesel or 2.6 tonnes of CO2 per year. Maintenance of the diesel particulate filters now only needs to be undertaken every two years or after every 120,000 kilometres.
A further factor in the new Citaro's success as "Bus of the Year 2013" is its attractive and distinctive design. To accommodate the new engines, the engineers developed a new rear frame, which makes the vehicle 30 millimetres longer. The decorative facing to the domed rear end of the Citaro gives the bus a particularly dynamic profile, but neither the turning circle nor the overall height of the vehicle is affected by these modifications. An elegantly rounded, glass panel above the rear window further enhances the classy look of the new Citaro. The engine flap and rear light clusters have also been redesigned. Energy-saving and long-life LED units have been used for the tail lamps, brake lamps and indicators.
And of course the Citaro scored extremely well in terms of safety. It includes a new crash element to protect the driver in the event of a collision, while the bus was designed overall with consideration to the future ECE R 66/01 standard, which specifies a larger survival space for the interior in the event of the bus tipping over. Although this is not due to come into effect until 2017, passengers as well as the company are already able to enjoy the benefit of this extra level of safety. It has also been possible to make numerous elements of the bodyshell lighter and yet even stronger. Furthermore, the new Citaro is the first regular-service bus ever to feature ESP.
Mercedes-Benz Citaro Euro VI, exterior, driving shot
Passenger comfort was another area that saw the "Bus of the Year" jury vote for the Citaro. Seen on the approach to a bus stop, the bus already looks inviting: the entry and exit areas at each door are brightly lit with a broad LED lighting band. This friendly lighting concept continues in the interior, ensuring a welcoming atmosphere. With the roof vent flaps acting as reflectors, the ceiling lights convey the effect of indirect lighting. Additional lighting elements have been used to create discrete quiet areas and reading corners while, at the same time, the good level of illumination in the rear section of the vehicle helps to reduce the risk of vandalism. The new design of the horizontal grab rails means that they can be used both for the integration of additional lighting elements and for interchangeable advertising inserts or even scrolling text, thus opening up whole new possibilities for companies to generate additional income through advertising.
The Citaro driver can be sure of enjoying a freshly designed workspace that sets new standards in terms of ease of use, ergonomics, instrumentation and comfort. The door to the driver's cab is hinged at the rear and opens from the front, so ensuring direct access from the front door to the driver's seat and vice versa. The stowage facilities in the door have been improved and now offer a larger compartment for the driver's bag as well as a section for a drinks bottle. The partition to the driver's working area is larger than before and features a wider forward curvature.
Source: http://www.evobus.com/inter-evobus/0-67 ... 0-0-0.html
Re: Innovative Mercedes-Benz Citaro is "Bus of the Year 2013
Mesajde Trifu22 pe 22 Sep 2012, 18:15
ar fi buna versiunea cu burduf pentru Bucuresti (bulevardele mari)
Mesajde Daniel pe 23 Sep 2012, 01:01
Nimic de zis. Arata bine, ultramoderne. Si eu prefer versiunea articulata. Insa in Europa, inafara de Mercedes mai exista si altceva dupa ce au cumparat toate celelalte firme din domeniu? Cum naiba sa nu iasa aftobuzu' anului cand celelalte marci sunt tot ale lor si intentionat sunt tinute mai jos calitativ??? :lol: :lol: :lol:
Mesajde zofei.2006 pe 23 Sep 2012, 11:21
Era sa uit de filmul de prezentare a noului model mercedes Citaro Euro 6.
Mesajde zofei.2006 pe 23 Sep 2012, 11:55
Daniel scrie:Nimic de zis. Arata bine, ultramoderne. Si eu prefer versiunea articulata. Insa in Europa, inafara de Mercedes mai exista si altceva dupa ce au cumparat toate celelalte firme din domeniu? Cum naiba sa nu iasa aftobuzu' anului cand celelalte marci sunt tot ale lor si intentionat sunt tinute mai jos calitativ??? :lol: :lol: :lol:
Hai ca deja exagerezi Daniel doar Setra apartine concernului Daimler, ai uitat cumva de Iveco, Volvo, Scania, VDL, etc.
Sa nu uitam ca in 2011 castigator a fost VDL Citea, asa ca nu zice ca Mercedes castiga in fiecare an ;) .
http://www.vdlgroep.com/?news/491252/VDL+Citea+voted+Bus+of+the+Year+2011.aspx
Citaro Euro VI a fost desemnat autobuzul anului 2013
Mesajde zofei.2006 pe 23 Sep 2012, 12:02
Inovatiile tehnice, designul si elementele de siguranta au fost numai o parte dintre caracteristicile care au indemnat juriul de experti din cadrul “Bus of the Year 2013” sa ofere acest premiu noului Mercedes-Benz Citaro cu motor Euro VI.
Pentru a fi in conformitate cu standardul Euro VI, noul Citaro este dotat cu un sistem de control al emisiilor, care combina tehnologia Mercedes-Benz SCR - cu injectie AdBlue - cu un convertor cu oxidare catalitica de recirculare a noxelor. Aceasta noua generatie de motoare, impreuna cu sistemul de control al emisiilor nocive, a primit un punctaj mare din partea juriului “Bus of the Year 2013”.
Mai mult decat atat, noul Citaro cu Euro VI are un consum mai mic de combustibil, in ciuda faptului ca dotarea cu o astfel de motorizare ar presupune un consum mai mare. Autobuzele sunt dotate cu noua generatie de motoare Mercedes-Benz Bluetec: OM 936, cu o capacitate de 7,7 litri şi 299 CP. Conform graficelor, in comparatie cu motorizarea pentru Euro V, noile Bluetec au un consum mai mic si sunt mai reduse in greutate.
Trofeul “Bus of the Year 2013” a fost acordat castigatorului pe 18 septembrie, in cadrul targului international IAA, de la Hanovra. Noul Citaro ramane in continuare primul autobuz dotat cu tehnologia Euro VI, intrat deja in productie.
Sursa: http://transporter.ro/s-10253-Stiri-Cit ... nului-2013
Mesajde Trifu22 pe 23 Sep 2012, 14:49
:)) IN CE ALT ORAS DIN ROMANIA ELEVII VIN LA SCOALA CU MERCEDES :))
Mesajde zofei.2006 pe 23 Sep 2012, 15:01
Trifu22 scrie::)) IN CE ALT ORAS DIN ROMANIA ELEVII VIN LA SCOALA CU MERCEDES :))
La Timisoara, Cluj, etc :D .
Mesajde Cornel Grigore pe 23 Sep 2012, 22:18
Ultima oară modificat de Cornel Grigore pe 30 Sep 2012, 11:59, modificat 1 dată în total.
Mesajde zofei.2006 pe 23 Sep 2012, 22:19
CORNEL96 scrie:de ce nu fac la fel ca cei din Olanda ?autobuze de 30 de metrii?
Ce intrebare stupida, ai pus cornele . Intrebai pe ei nu pe noi .
Mesajde Chev Celios pe 27 Sep 2012, 14:31
Incearca tu Cornele sa mergi cu un autobuz de 30 de metri pe bulevardele si strazile aglomerate din Bucuresti.Si probabil ca nu ar avea nici o piata foarte mare de desfacere. Sa nu uitam de modelul Cappa City care acum nu se mai produce.
Mesajde Daniel pe 27 Sep 2012, 15:19
Se poate merge si cu un autobuz de 30 de metri lungime. Insa, acestea sunt mai scumpe si autoritatile nu au bani. Dovada cele 5 bucati troleibuze noi care vor sosi la RATB, cand acolo ar fi nevoie de mai multe. Cum vrei tu sa aiba astia bani de autobuze articulate??? La Milano se parcheaza ca si la noi pe strazi si circula:
De ce nu ar merge si la Bucuresti??? :lol:
Mesajde Chev Celios pe 27 Sep 2012, 16:45
Alea au undeva la 20 de metri. Cornel se referea la astea care apropo sunt din Germania nu din Olanda si se numesc Goopel Bus AutoTram Extra Grand Bus:
http://www.digitaltrends.com/internatio ... -long-bus/
Mesajde Daniel pe 27 Sep 2012, 17:00
Cred ca s-ar putea circula si cu astea de 30m. Insa, eu ma refeream in general la tampeniile aruncate pe net in ultimii ani, conform carora in Bucuresti nu pot circula articulate de niciun fel. Pai daca ar fi asa, avem o problema: fie soferi prosti, fie Politia Rutiera e la pamant. Asa mi-as dori si eu un hibrid gen ExquiCity de la VanHool pe strazile Bucurestiului... :pray:
Imagine Si nu are decat vreo 23 820 mm
... 8-)
Mesajde zofei.2006 pe 27 Sep 2012, 21:42
Daniel scrie:Cred ca s-ar putea circula si cu astea de 30m. Insa, eu ma refeream in general la tampeniile aruncate pe net in ultimii ani, conform carora in Bucuresti nu pot circula articulate de niciun fel. Pai daca ar fi asa, avem o problema: fie soferi prosti, fie Politia Rutiera e la pamant. Asa mi-as dori si eu un hibrid gen ExquiCity de la VanHool pe strazile Bucurestiului... :pray:
... 8-)
Hai ca deja o dai SF-uri, la cum se parcheaza in Bucuresti nu poti folosii articulate, de exemplu pe Luterena, Dorobanti, etc. Daniel ia te rog 178 de la Sala Palatului pana la Biserica Luterena sa vezi ce manevre trebuie sa faci cu un Citaro ca sa intorci. Asa ca documenteazate inainte sa spui porcarii .
Am avut un articulat care a circulat in linia 381 doar aco
Mesajde Daniel pe 27 Sep 2012, 22:56
Multe din traseele si terminalele RATB sunt prost gandite. Pe de alta parte nimeni nu rezolva problema autoturismelor parcate aiurea.
Mesajde zofei.2006 pe 28 Sep 2012, 12:15
Daniel scrie:Multe din traseele si terminalele RATB sunt prost gandite. Pe de alta parte nimeni nu rezolva problema autoturismelor parcate aiurea.
This is Romania, f.u.c.k. Romania .
Ultima oară modificat de Daniel pe 29 Sep 2012, 18:12, modificat de 2 ori în total.
Mesajde Daniel pe 29 Sep 2012, 18:13
Andrei, am modificat si eu putin postul. Il inteleg perfect pe Zofei, din pacate a zis un adevar. :(
Înapoi la DISCUTII GENERALE DESPRE TRANSPORT PUBLIC / VARIOUS DISCUSSIONS ABOUT P.T.
