Plasser & Theurer DGS 62 N
Utilaje de cale / Railway maintenance vehicles
Mesajde zofei.2006 pe 11 Noi 2010, 22:30
Plasser & Theurer DGS 62 N Plasser Dynamic Track Stabiliser
The Plasser DTS 62 Dynamic Track Stabiliser is designed to apply controlled, accurate stabilising forces into the track structure at continuous speeds of up to 1.5 km/h.
All track is subject to settling due to traffic loads. This settling occurs irregularly and in an uncontrolled manner, resulting in track deterioration. Dynamic track stabilisation is a combination of horizontal vibration and a vertical load.
The stabilising unit is a well proven design developed in 1975 with more than 400 machines in regular use on various railroads worldwide since 1978.
Technical Data
Length: 17,250 mm
Width: 2,850 mm
Height: 3,660 mm
Weight: 65 t
Bogie centres: 12,000 mm
Wheel diameter: 730 mm
Engine power: 350 kW
Travel speed: 80 km/h
Drawing
Re: Plasser & Theurer DGS 62 N
Mesajde mikeattila pe 13 Ian 2011, 15:32
Cele mai performante utilaje de cale pentru intretinerea caii. Stabilizatorul are un rol important si scurteaza procesul tehnologic la readucerea caii in limitele instructionale. De retinut ca este de ajuns o singura trecere si asta inseamna un tonaj de stabilizare a caii de 120 000 tone.
Înapoi la ALTE CATEGORII (material rulant de alt tip) / OTHER type of rolling stock
