Plasser & Theurer SSP 2005 SWR
Utilaje de cale / Railway maintenance vehicles
Mesajde zofei.2006 pe 11 Noi 2010, 23:14
Plasser & Theurer SSP 2005 SWR Ballast Distributing and Profiling Machine (For tracks, switches and crossings with ballast hopper)
Machine with two 2-axle bogies carrying: split center plough, suitable for ploughing in tracks with line conductor, ballast flow can be selected via symbol switch, shoulder ploughs, sweeper unit with transverse conveyor belt, steep conveyor belt and ballast hopper with floor conveyor belt and distribution chutes, hydrostatic drives on all axles, UIC brakes, spacious cabin with 2 driver’s desks and end windscreens made of 14 mm safety glass.
Variable machine accessories: dust arresting atomizer unit with water tank, sweeper unit displaceable by ±100 mm for work in station platform area, loading device for brush shaft, rail fastening brush, slewing limitation for shoulder ploughs, cabin fittings, inductive switches, driver’s safety device and train radio, pneumatically operated barrier to access steps, external controls for driving function.
Technical Data
Length over buffers: 19 000 mm
Height over top of rail: 4 630 mm
Width: 3 100 mm
Distance between bogie pivots: 11 500 mm
Wheelbase of the bogies: 1 500/1 800 mm
Total mass empty: 53 t
Engine output: 400 kW
Max. travelling speed under own power/towed: 100 km/h
Drawing
Re: Plasser & Theurer SSP 2005 SWR
Mesajde mikeattila pe 13 Ian 2011, 16:19
O masina de vis pentru cele mai grele lucrari de intretinere cum este si completarea, profilarea pietrei sparte, mai ales ca are si buncar de depozitare. Randamentul este eficient atunci cind are un front de lucru de aproximativ 10 ore de inchidere tinind cont de pretul foarte mare a utilajului.
Mesajde kdlehel pe 13 Ian 2011, 23:53
foarte fain pozele. Des am Investighat situl lui plasser.
Favoritul meu care bate sub traverse este Unimat 09-32/4s Dynamic care poate sa stabilizeze si macazele. Masini de masurare ca EM-SAT 120 si UFM - 120 si masini de montare catenara ca FUM 100 Plasser&Theurer technolige de constructia si reinnoire a caii ferate in mod rapid si sigur.
Mesajde Daniel pe 24 Mai 2011, 16:29
Ei bine, un SSP 2003 de aceasta data dar si alte jucarii aici! :)
Mesajde Andrei Irimescu pe 12 Aug 2011, 14:41
In Slatina :)
Mesajde Andrei Irimescu pe 21 Aug 2011, 23:47
Slatina
Înapoi la ALTE CATEGORII (material rulant de alt tip) / OTHER type of rolling stock
