Cetate Bavareza la scara Z!/Bavarian citadel on Z scale!
Mesajde Daniel pe 07 Dec 2012, 01:27
Cetate taraneasca Bavareza din secolul al XVI-lea la scara Z (1:220)! Bavarian peasant citadel from the XVI-th century on Z scale (1:220)!
Cetate Bavareza scara Z. Bavarian citadel on Z scale / Foto: LUCIUS
Ei bine, scara Z este o scara destul de nou aparuta in modelismul feroviar si are foarte putini adepti in Romania. In acest moment, cu exceptia prietenului nostru Lucian (LUCIUS) eu nu mai cunosc. Producatorii de accesorii pentru astfel de diorame sunt foarte putini si au preturi exorbitante. Pornind de la acest fapt, Lucian, m-a desemnat sa-i prezint ultimele lucrari pe aceasta tema. Pe LUCIUS il mai stiti de cand cu macheta la aceeasi scara a garii Curtea de Arges, o capodopera arhitectonica feroviara. Daca intre timp la gara cu pricina inca mai este de lucru, iata ca au vazut lumina zilei o cetate bavareza si un mic bloc. Pentru ca Lucian duce lipsa de timp liber pentru a va prezenta chiar el aceasta macheta care va va uimi cu adevarat, am sa va reproduc eu imaginile si textul pe care el mi le-a furnizat pe parcursul a cateva episoade, care sper sa se constituie intr-un ghid util in cazul in care doriti sa realizati si voi asa ceva.
Oh well, the Z scale its quite new on the model train world and it has very few followers in Romania. On this moment, except for our friend Lucian (LUCIUS) I don’t know any other. The accessories producers for such a layout are very few and they have prohibit prices. Starting from this fact, Lucian asked me to show you all his work. You all must remember LUCIUS, the one who built the model of the Curtea de Arges railway station on the same Z scale, a real masterpiece of railway architecture. If, in the meantime, the station needs to be completed, a Bavarian peasant citadel and a small block-house saw the daylight. Because Lucian is not having enough time to show you his really amazing works, I will have “the mission” to offer you his pictures and explanations. I hope this will be a useful guide in case you wish to create something similar.
CETATE 01 / Foto: LUCIUS
Materialul folosit este un plastic special pentru modelaj, folosit adesea la realizarea decorurilor, cu o grosime de 2.5mm. Cetatea noastra are patru componente.
The material used is a special plastic for modeling, used often to build sceneryes (mise en scenes), and is 2.5mm thick. Our citadel has four parts.
1. Corpul principal / Building’s main body
2. Turnul fortificat / The fortified tower
3. Structura de baza / The basic structure
4. Zidul de incinta si turnul de observatie / The enclosure wall and observation tower
CETATE 02 / Foto: LUCIUS
CETATE 06 / Foto: LUCIUS
CETATE 07 / Foto: LUCIUS
CETATE 08 / Foto: LUCIUS
CETATE 10 / Foto: LUCIUS
CETATE 11 / Foto: LUCIUS
CETATE 12 / Foto: LUCIUS
Dupa realizarea proiectului se traseaza placile din plastic. Se incepe cu corpul principal. Componentele turnului raman laolalta pana la trasarea pietrelor. Pentru a reda cat mai realist bolovanii, fiecare dintre acestia se realizeaza manual cu o surubelnita de mici dimensiuni. Urmeaza decupajul ferestrelor cu un cutter dupa care se finiseaza.
After the project is ready, the plastic boards are being mapped. It begins with the main body of our construction. The tower’s components are staying together until the stones are being drawn. For a more realistic reproduction of the boulders, each of them are manually accomplished with a small screwdriver. Cutting and finishing the windows using a cutter, is the next step.
CETATE 14 / Foto: LUCIUS
CETATE 15 / Foto: LUCIUS
CETATE 03 / Foto: LUCIUS
CETATE 04 / Foto: LUCIUS
CETATE 05 / Foto: LUCIUS
CETATE 09 / Foto: LUCIUS
CETATE 16 / Foto: LUCIUS
CETATE 17 / Foto: LUCIUS
CETATE 18 / Foto: LUCIUS
CETATE 19 / Foto: LUCIUS
Se decupeaza cu grija fiecare perete. Every wall is carefully cut up.
CETATE 20 / Foto: LUCIUS
CETATE 21 / Foto: LUCIUS
CETATE 22 / Foto: LUCIUS
De remarcat faptul ca marginile corpului principal au o structura ca de caramida pentru a le pune in evidenta. Notice that the main body’s structure edges, have a brick-like shape in order to highlight them.
CETATE 13 / Foto: LUCIUS
Se dubleaza interiorul cu o folie adeziva neagra. The interior is covered with a black adhesive foil.
CETATE 24 / Foto: LUCIUS
Folia are rolul de a nu permite luminii sa patrunda prin pereti ci numai prin ferestre in momentul iluminarii machetei. La imbinari marginile peretilor vor fi ajustate la 45° pentru o mai buna asamblare. The foil acts like a shutter to prevent the light to penetrate through the walls, and to let the light pass only through the windows, when the building is lighted (interior lights). At the joints the walls edges will be adjusted to 45° for a better assembly.
CETATE 23 / Foto: LUCIUS
Corpul principal ar arata cam asa: / The building’s main body will look like this:
CETATE 25 / Foto: LUCIUS
Dupa asamblare “turnul fortificat” trebuie rectificat la muchii ca sa nu se observe imbinarea. After the assembling the “fortified tower” it’s edges must be corrected in order to hide the assemblage traces.
CETATE 26 / Foto: LUCIUS
CETATE 27 / Foto: LUCIUS
CETATE 28 / Foto: LUCIUS
Structura de piatra a peretilor este conceputa in asa fel incat creeaza impresia de continuitate. The walls stone structure is designed so, to create the impression of continuity.
Se incearca diverse variante de asamblare. Different ways of assembling are being tested.
CETATE 29 / Foto: LUCIUS
CETATE 30 / Foto: LUCIUS
CETATE 31 / Foto: LUCIUS
CETATE 32 / Foto: LUCIUS
CETATE 33 / Foto: LUCIUS
CETATE 34 / Foto: LUCIUS
Va urma! Will be continued! :dance:
Re: Cetate Bavareza la scara Z! / Bavarian citadel on Z scal
Mesajde Trifu22 pe 10 Dec 2012, 16:34
Kolomotiv, salivati in continuare!
Kolomotiv, EAT YOUR HEART OUT!!!
ah, am uitat sa precizez ca voi colabora la construirea sistemului electronic ANALOGIC ce va controla semnalele (in mod automat, tip BLA), macazurile si alte componente! totul cu relee si GTO
Mesajde zofei.2006 pe 10 Dec 2012, 23:43
Trifu22 scrie:Kolomotiv, salivati in continuare!
Ai grija te rog eu mult la limbaj, totusi nu trebuie sa ne laudam ca stii si tu ca , lauda a sine nu miroase a bine ;) .
Peace trifule :D .
Mesajde Daniel pe 11 Dec 2012, 13:04
Hai sa lasam polemicile astea inutile si sa ne pregatim pentru urmatoarea parte a descrierii. Mai e mult de scris... ;)
Mesajde Daniel pe 18 Dec 2012, 22:46
Partea a doua! Part two!
CETATE 35 / Foto: LUCIUS
Se proiecteaza si se decuperaza acoperisul “turnului fortificat”. The roof of the “fortified tower” is being designed and cut up. (35-42)
CETATE 36 / Foto: LUCIUS
CETATE 37 / Foto: LUCIUS
CETATE 38 / Foto: LUCIUS
CETATE 39 / Foto: LUCIUS
CETATE 40 / Foto: LUCIUS
CETATE 41 / Foto: LUCIUS
CETATE 42 / Foto: LUCIUS
Acoperisul este format din doua piese cu unghiuri diferite care trebuie sa se imbine perfect. The roof is composed by two parts with different angles which must be perfectly assembled. (43)
CETATE 43 / Foto: LUCIUS
Se asambleaza provizoriu. Those parts must be temporarily assembled, first. (44-47)
CETATE 44 / Foto: LUCIUS
CETATE 45 / Foto: LUCIUS
CETATE 46 / Foto: LUCIUS
CETATE 47 / Foto: LUCIUS
Se proiecteaza elementele acoperisului corpului principal. The main body’s structure elements are being designed first. (48-62)
CETATE 48 / Foto: LUCIUS
CETATE 49 / Foto: LUCIUS
CETATE 50 / Foto: LUCIUS
CETATE 51 / Foto: LUCIUS
CETATE 52 / Foto: LUCIUS
CETATE 53 / Foto: LUCIUS
CETATE 54 / Foto: LUCIUS
CETATE 55 / Foto: LUCIUS
CETATE 56 / Foto: LUCIUS
CETATE 57 / Foto: LUCIUS
CETATE 58 / Foto: LUCIUS
CETATE 59 / Foto: LUCIUS
CETATE 61 / Foto: LUCIUS
CETATE 62 / Foto: LUCIUS
Acoperisurile sunt mai apoi fixate definitive cu adeziv UHU. The roofs will be fixed for good, bonded with UHU adhesive. (60)
CETATE 60 / Foto: LUCIUS
CETATE 63 / Foto: Daniel
CETATE 64 / Foto: Daniel
CETATE 65 / Foto: Daniel
CETATE 66 / Foto: Daniel
CETATE 67 / Foto: Daniel
CETATE 68 / Foto: Daniel
CETATE 69 / Foto: LUCIUS
Pentru a face o comparative, se alatura o gara de serie si un bloc-vila. To do a comparative join, a serial produced railstation among with a small mansion block are being placed near our citadel. (70,71)
CETATE 70 / Foto: LUCIUS
CETATE 71 / Foto: LUCIUS
Se concepe un mic balcon si structura exterioara de rezistenta de sub balcon. A small balcony is created together with the structural strength under the balcony. (72.73)
CETATE 72 / Foto: LUCIUS
CETATE 73 / Foto: LUCIUS
Va urma! Will be continued! ;)
Mesajde Daniel pe 14 Feb 2013, 19:17
Partea a patra. Part four.
CETATE 74 / Foto: LUCIUS
Structura de baza – este structura pe care se vor fixa corpurile si iluminarea (74-77). The basic structure – on this structure, the building’s two bodies will be fixed on (74-77).
CETATE 75 / Foto: LUCIUS
CETATE 76 / Foto: LUCIUS
CETATE 77 / Foto: LUCIUS
La structura de baza se adauga o diferenta de nivel dotata cu scari. Scarile sunt realizate din mai multe piese ulterior asamblate (78-92) si (100-117). A level difference will be added to the basic structure, a difference that will be gifted with stairs. The stairs are being formed from many pieces assembled after (78-92) and (100-117).
CETATE 78 / Foto: LUCIUS
CETATE 79 / Foto: LUCIUS
CETATE 80 / Foto: LUCIUS
CETATE 81 / Foto: LUCIUS
CETATE 82 / Foto: LUCIUS
CETATE 84 / Foto: LUCIUS
CETATE 85 / Foto: LUCIUS
CETATE 86 / Foto: LUCIUS
CETATE 87 / Foto: LUCIUS
CETATE 88 / Foto: LUCIUS
CETATE 89 / Foto: LUCIUS
CETATE 90 / Foto: LUCIUS
CETATE 92 / Foto: LUCIUS
CETATE 100 / Foto: LUCIUS
CETATE 101 / Foto: LUCIUS
CETATE 102 / Foto: LUCIUS
CETATE 104 / Foto: LUCIUS
CETATE 105 / Foto: LUCIUS
CETATE 106 / Foto: LUCIUS
CETATE 108 / Foto: LUCIUS
CETATE 109 / Foto: LUCIUS
CETATE 110 / Foto: LUCIUS
CETATE 111 / Foto: LUCIUS
CETATE 112 / Foto: LUCIUS
CETATE 114 / Foto: LUCIUS
CETATE 115 / Foto: LUCIUS
CETATE 116 / Foto: LUCIUS
CETATE 117 / Foto: LUCIUS
CETATE 119 / Foto: LUCIUS
Se asambleaza diferentele de nivel (93-99). The two level differences are being assembled (93-99).
CETATE 93 / Foto: LUCIUS
CETATE 95 / Foto: LUCIUS
CETATE 96 / Foto: LUCIUS
CETATE 97 / Foto: LUCIUS
CETATE 98 / Foto: LUCIUS
CETATE 99 / Foto: LUCIUS
Vor fi doua diferente de nivel, una in stanga si cealalta in dreapta celor doua corpuri ale cetatii (120-123). At the end we will have two level differences, one in the left of the two buildigs of the citadel, and the other on the right side (120-123).
CETATE 120 / Foto: LUCIUS
CETATE 121 / Foto: LUCIUS
CETATE 122 / Foto: LUCIUS
CETATE 123 / Foto: LUCIUS
See you next time! :dance:
Re: Cetate Bavareza la scara Z!/Bavarian citadel on Z scale!
Mesajde Daniel pe 30 Mar 2013, 12:33
Partea a V-a. The V-th part.
Continuam prezentarea realizarii acestei cetati in imagini. Practic, pana la rezultatul final nu mai este mult. In continuare, fara alte explicatii, vom vedea cum se asambleaza diferitele parti ale cetatii si cum se modeleaza pietrele zidurilor.
We continue to present you how this citadel is maded. Untill the final result, it won't take too long. Without any other explanations, we will see how different parts of the cidatel are being putted together, and how the stone walls are maded. :dance:
CETATE 124 / Foto: LUCIUS
CETATE 125 / Foto: LUCIUS
CETATE 126 / Foto: LUCIUS
CETATE 127 / Foto: LUCIUS
CETATE 128 / Foto: LUCIUS
CETATE 129 / Foto: LUCIUS
CETATE 130 / Foto: LUCIUS
CETATE 131 / Foto: LUCIUS
CETATE 132 / Foto: LUCIUS
CETATE 133 / Foto: LUCIUS
CETATE 134 / Foto: LUCIUS
CETATE 138 / Foto: LUCIUS
CETATE 139 / Foto: LUCIUS
CETATE 140 / Foto: LUCIUS
CETATE 141 / Foto: LUCIUS
CETATE 142 / Foto: LUCIUS
CETATE 144 / Foto: LUCIUS
CETATE 145 / Foto: LUCIUS
CETATE 146 / Foto: LUCIUS
CETATE 147 / Foto: LUCIUS
CETATE 149 / Foto: LUCIUS
CETATE 151 / Foto: LUCIUS
CETATE 153 / Foto: LUCIUS
CETATE 154 / Foto: LUCIUS
CETATE 157 / Foto: LUCIUS
CETATE 159 / Foto: LUCIUS
CETATE 160 / Foto: LUCIUS
CETATE 161 / Foto: LUCIUS
CETATE 162 / Foto: LUCIUS
CETATE 163 / Foto: LUCIUS
CETATE 164 / Foto: LUCIUS
CETATE 165 / Foto: LUCIUS
See you next time! ;)
Mesajde kid72 pe 05 Apr 2013, 01:21
Modelismul, de orice fel, inseamna munca si rabdare, nu intotdeauna pretuite de cei din jur (incepand cu propria familie...). Azi exista ca alternativa si modelismul virtual 3-D (a nu se confunda cu jocurile pe calculator cu trenuletze), fara sa ne mai murdarim pe maini si fara teama de a gresi cand taiem. Se face inclusiv interiorul (locomotivei), cu motor, cabina, chiar detalii precum trusa de scule a mecanicului si stingatoarele de incendiu. Dar lipseste materia prima de baza, ...timpul.
kid72
Mesajde Daniel pe 06 Apr 2013, 08:51
Asa este. LUCIUS va mai veni cu un alt proiect si lucreaza printre picaturi, tot la scara Z la replica in miniatura a garii Curtea de Arges care va iesi o adevarata bijuterie. Luni voi veni si cu ultima parte a acestei lucrari unice in Romania. ;)
Mesajde Daniel pe 03 Mai 2013, 14:36
Astazi veti avea de vazut si ultimele imagini ale realizarii acestei lucrari, care in mod sigur este una destul de meticuloasa si dificil de realizat. Cred ca asteptarea a meritat!
Today you will have to see the last images of this work, that is for sure a meticulous one and hard to achieve. I think it worth the wait!
CETATE 166. / Foto: LUCIUS
CETATE 167. / Foto: LUCIUS
CETATE 168. / Foto: LUCIUS
CETATE 169. / Foto: LUCIUS
CETATE 170. / Foto: LUCIUS
CETATE 171. / Foto: LUCIUS
CETATE 172. / Foto: LUCIUS
CETATE 173. / Foto: LUCIUS
CETATE 174. / Foto: LUCIUS
CETATE 175. / Foto: LUCIUS
CETATE 177. / Foto: LUCIUS
CETATE 178. / Foto: LUCIUS
CETATE 179. / Foto: LUCIUS
CETATE 183. / Foto: LUCIUS
CETATE 184. / Foto: LUCIUS
CETATE 185. / Foto: LUCIUS
CETATE 186. / Foto: LUCIUS
CETATE 187. / Foto: LUCIUS
CETATE 188. / Foto: LUCIUS
CETATE 189. / Foto: LUCIUS
CETATE 190. / Foto: LUCIUS
CETATE 191. / Foto: LUCIUS
CETATE 192. / Foto: LUCIUS
CETATE 193. / Foto: LUCIUS
CETATE 194. / Foto: LUCIUS
CETATE 195. / Foto: LUCIUS
CETATE 196. / Foto: LUCIUS
CETATE 197. / Foto: LUCIUS
CETATE 199. / Foto: LUCIUS
CETATE 200. / Foto: LUCIUS
CETATE 202. / Foto: LUCIUS
CETATE 203. / Foto: LUCIUS
CETATE 204. / Foto: LUCIUS
CETATE 205. / Foto: LUCIUS
CETATE 206. / Foto: LUCIUS
CETATE 207. / Foto: LUCIUS
CETATE 208. / Foto: LUCIUS
CETATE 210. / Foto: LUCIUS
CETATE 211. / Foto: LUCIUS
CETATE 212. / Foto: LUCIUS
CETATE 213. / Foto: LUCIUS
CETATE 214. / Foto: LUCIUS
CETATE 215. / Foto: LUCIUS
CETATE 216. / Foto: LUCIUS
Pana in acest moment, ramane singurul proiect de acest fel din Romania. Astept cu interes proiectele urmatoare ale lui LUCIUS! Untill now, the project remains unique in Romania. I am waiting with much interest the next projects of LUCIUS! :dance:
Înapoi la Alte scari / Other scales: TT (1:120) "12mm" / N (1:160) "9mm" / Z (1:220) "6mm" / etc.
