SEMAFOARE SI SEMNALE, INDICATOARE, BARIERE, INSTALATII DE ASIGURARE, CENTRALIZARE, MECANIZARE, TELECOMUNICATII, AUTOMATIZARE TRIERE VAGOANE, MASA DE MANEVRA.
